T.A. Dis-assembly
SDE
08-09-2007 05:15:05
According to the DVD, the over-running clutch requires an allen wrench to remove 4 cap-screws.
On my 400, then are 4 bolts and neither a 7/16 or 3/8 fit them. A 10mm socket slips off them.
The TA clutch Disc still has white lettering visible on it. Someone rebuilt it not to long ago. Are these some odd-ball replacement bolts or are they a standard bolt for the 400? and are they 13/32? The parts store can order a socket for me but is this really the right size?
SDE
SDE
08-12-2007 07:25:18
 Re: T.A. Dis-assembly in reply to SDE, 08-09-2007 05:15:05
Got back from camping yesterday. Thank you for the info.
SDE
RR Mech
08-09-2007 20:24:46
all the later ones were 3/8 12 point. it has to be a fairly thin walled socket to fit down in deep enough to get a good hold.
D Slater
08-09-2007 13:53:54
Some are 3/8 inch 12 point socket and some allen, never run across another size yet.
georgeky
08-09-2007 11:40:42
They should be Allen head bolts.
