706 Pump Timing.
Opa A
08-09-2007 11:19:17
Wondering if anyone has the correct static timing spec for a 706 with Roosa Master injection pump. I believe it has the D282 engine. When I pulled the pump off for overhaul I lined up the timing marks in pump window and at that point the flywheel marks were at 10 degrees ATDC. I installed the rebuild pump at the same location and it ran terrible, white smoke and missing at all rpm. I readjusted the timing to 6 degrees BTDC as thats the closest spec I could find, it starts and runs alot better but still has a flutter at higher rpm. Any help would be greatly appreciated. Local dealer could not find spec.
ejr-IA.
08-09-2007 12:35:53
 Re: 706 Pump Timing. in reply to Opa A, 08-09-2007 11:19:17
TDC
Opa A
08-10-2007 12:02:59
 Re: 706 Pump Timing. in reply to ejr-IA., 08-09-2007 12:35:53
Thanks
