Ignition switch on a Farmall A
history guy
08-09-2007 21:10:09
How do I hook up the ignition switch on a farmall A and where is it mounted at to be in the original spot? Thanks!!!! I do not know what I would do without you guys!
Aaron
history guy
08-10-2007 08:59:31
 Re: Ignition switch on a Farmall A in reply to history guy, 08-09-2007 21:10:09
Thank you so much guys! I love this website!
Semper Fi!
Aaron
gene bender
08-10-2007 04:50:10
There should be a little bracket welded to the throttle fixed part and the sw mounted upright. All Bs came with a MAG.
history guy
08-09-2007 21:27:28
I have a magneto so I just need the one terminal switch and just hook it up to the magneto correct? I do not need to wire it to anything else right?
Aaron
Thanks!! I am new to this!
Farmer Bob
08-09-2007 21:38:24
 Re: Ignition switch on a Farmall A in reply to history guy, 08-09-2007 21:27:28
That's correct! One wire from the switch to the side center screw on the outside of the mag housing. Ensure the switch has a good ground on the bracket and between the bracket and the steering post.
Farmer Bob
08-09-2007 21:25:23
It depends on whether you have a magneto or a distributer. Switches on tractors with mags only have one screw contact. Switches on tractors with distributers have two contact screws. Let us know which one you have. As far as where the switch is mounted, the normal place in on a bracket mounted to the steering column post to the right of the throttle. It sits vertical with the knob of the switch pointing up.
history guy
08-09-2007 21:25:06
So it is just wired to the magneto and then grounded. It is the two terminal switch since I am using a battery right? Thank you for your help!
dave guest
08-09-2007 21:23:00
Kill switch. Grounds out magneto. Think on steering support. Too rainy or I could go out and tell you.
Janicholson
08-09-2007 21:33:29
 Re: Ignition switch on a Farmall A in reply to dave guest, 08-09-2007 21:23:00
If a mag, the switch is grounded so it will ground the wire going to the magneto when pushed in. If coil ignition, the switch provides power from the generator side of the amp meter, to the coil when pulled out. Way different switches. JimN
HENRY E NC
08-10-2007 05:59:20
 Re: Ignition switch on a Farmall A in reply to Janicholson, 08-09-2007 21:33:29
Since you have a magneto a single pole switch is required. There is no connection with the battery. Make sure when you mount the switch that all the paint is off the mounting bracket and take the throttle plate loose and make sure bracket is grounded to the steering column (Clean of rust and paint. A single wire goes to the magneto and fastens at the place where there is a brass nut. Use the proper length machine screw to attach it. The switch should ground out the mag when pushed in and not ground when pulled out.
