Instrument panel IH 886
little man
08-09-2007 21:48:23
I just purchased an IH 886 and after degreasing and washing the engine I noticed the light in the upper right hand corner of the panel is staying on. It looks like a circle with an arrow pointing through it. Anyone know what this light indicates? I also have a light with a p that comes in when I push the clutch in and was wondering if that was normal? And if it's not to much to ask, my serial # is like U17445 would anyone know what the year of this tractor is? Thanks,
little man
08-10-2007 07:11:42
 Re: Instrument panel IH 886 in reply to little man, 08-09-2007 21:48:23
Thanks K.B.-826 I'll check it out
K.B.-826
08-09-2007 22:32:38
Looks like it's a 1981 model, last year they were built. The light with the round circle and the arrow, thats the air filter restriction indicator. Could be anything from a dirty filter to a bad sender or grounded out wire. Check the filter first. If the filter is OK, disconnect the wiring at the sender, which is located on the tube between the filter canister and the manifold, if the light goes out, sender is bad. If the light stays on, the wire from the sender to the light is grounded out. The light that comes on when you depress the clutch pedal is the trans lube pressure indicator. It is normal for it to come on when the pedal is depressed, and you may notice it blink when the TA is shifted.
