IH fast hitch to 3 point adapter Picture for Gary in Mozarks
AllanRogis
08-10-2007 13:22:22
I found a parts drawing of the IH fast hitch to 3 point adapter. It can be found by going to the Case IH Website at www.caseih.com/index. When you get there you can click on "United States". On that screen click on "Search for Parts". Click on Begin your search for parts "right here" on that screen. Type in "FARMALL" and click on search button. Click on "400 series farmall gas tractors", then click on "attachments". Then finally click on "442 Three Point Adapter. I may try to post a picture if I figure it out.
AllanRogis
08-13-2007 07:05:05
 Re: IH fast hitch to 3 point adapter Picture for Gary in Moz in reply to AllanRogis, 08-10-2007 13:22:22
I want to add that the fast hitch was designed to carry the weight of the implement without a 3rd link. I don't think the design would have been heavy for some of today's heavy implements. Thanks Hugh, for posting the picture.
Butch WI
08-12-2007 11:06:57
AllanRogis,
Is there a need for a top link in this application? Seems as if a heavy implement may cause the tongs to break. Although this is exactly what I need for I am in the search of 3 pt tongs.
Butch
AllanRogis
08-13-2007 06:56:44
 Re: IH fast hitch to 3 point adapter Picture for Gary in Moz in reply to Butch WI, 08-12-2007 11:06:57
It is built pretty heavy, it does handle 3 point rotary cutters, 4 row cultivators, and 8' blades. I use a 3 point hitch quick hitch with the straight fast hitch points for my 8 row cultivator when I used to cultivate. I installed the 3rd link on the rockshaft assembly to use the quick hitch. I had to weld heavy steel with holes drilled 5" below the regular holes in the quick hitch assembly.
HughB
08-11-2007 07:28:13
third party image
Let me see if I can bring it up.
