no regulator
smdv806
08-10-2007 16:02:55
Does anyone know how to wire up a tractor without using a regulator? I want to use a light or something to prevent overcharging. This is a 460 with a 12 volt generator. I have a MSD box that drains a lot and I am not really that concerned about overcharging. I use it as a pulling tractor and it doesn't get run much. Can I just wire the two posts on the generator to my battery? How do you polarize a generator without a regulator?
teddy52food
08-11-2007 07:01:58
 Re: no regulator in reply to smdv806, 08-10-2007 16:02:55
What is an MSD box? Just put in a cut out instead of a regulator. Ground the field wire to make it charge and if you do not want it to charge when pulling, just take it off.
City-Boy McCoy
08-10-2007 16:05:34
I'd say ask the boys over at the pulling forum.
mike durhan
