jeep snow plow
Pat-CT
08-10-2007 22:10:00
is there any way you could take a jeep snow plow fram or any truck snow plow frame and fit it to a farmall H really want a snow plow for this winter but cant find one localy
Andrew Z
08-11-2007 13:10:17
 Re: jeep snow plow in reply to Pat-CT, 08-10-2007 22:10:00
yup I run a 7 foot fisher on my H, I just mount it on the front of the old pipe loader that i have works well but is kinda heavy, if your ever close to Brooklyn come by and check it out.
Andrew
Nat 2
08-11-2007 08:03:00
Sure, you can do basically whatever you want with enough scrap steel, a torch and a welder. Figure out where the plow frame needs to hang in front of the tractor, and build out from the side rails with scrap steel to meet it. If in doubt, use heavier steel.
old
08-11-2007 07:17:49
I have a meyers snow plow I have set up to mount in front of my Allis C it works sort of ok but the C is just a little small for that 7.5 foot blade so yep it could be done but will take makeing a frame for it to hook to and a lift system. What I made for my C with some mods. could be set up to work on an H. Drop me an e-mail and I can send you a couple pictures of it
tinyy
08-11-2007 04:44:11
Me and my brother-in-law took a Meyers and put it on a JD1010 just made all mounting brakets for it used the plow pump for hydra-turn.If you got time,mony,and a weder you can make it work.
