international i-4
dennis vanpoper
08-12-2007 11:52:51
i have an international i-4.it says i-4 BH17843.does anyone know anything about this tractor?horsepower.yearwhat it was used for?it is red.what farmall tractor is based on?it has 14.9-24tires that are loaded.thanks
Athol Carr
08-12-2007 22:42:06
 Re: international i-4 in reply to dennis vanpopering, 08-12-2007 11:52:51
If it has an I-4 engine the engine serial number (on the right-hand side of block, below number 1 (front) spark plug)) should start with IBHM followed by 3 to 5 digit number. They do not match tractor number but should not be too, too different. My 1941 W-4 is missing the W from both model number and tractor serial number but does have the W on the engine number. Tractor model 4, serial BH 2381, Engine WBHM 2133
Wardner
08-12-2007 13:31:43
If your I-4 still has the spring loaded pintle hook, Harold H and myself would appreciate your taking some measurements on the lower arms (struts). Specifically the following measurements:
dimension of bar stock
bolt diameter where bar attaches to pintle receiving casting
overall length from end of bar to end of welded pipe section (hinge).
Now to your question. Bore size was increased when the Super H was built. You have a later tractor or motor. Bore on that same basic motor was increased again when the 350 was built. Send us the serial number of the tractor and also look for cast numbers on the block above the oil filter. The number should begin with a C.
Harold H
08-12-2007 13:15:35
 Re: International I-4 in reply to dennis vanpopering, 08-12-2007 11:52:51
Dennis,
Your I-4 is a 1947, the same year as the one I am restoring. Nebraska test was 27.89 belt horsepower and 25.67 drawbar horsepower. It has the same 152.1 cubic inch engine as the H. Red was the standard color. Highway orange was a no cost factory option color. IHC would paint the I-4 any other color the customer wanted. I have debated between red an orange for mine but have decided to go with the orange color. Does you tractor have a pintle hitch? Mine has a homemade regular drawbar but I am in the process of locating a pintle hitch fo it.
Harold H
dennis vanpopering
08-16-2007 18:31:53
 Re: International I-4 in reply to Harold H, 08-12-2007 13:15:35
no hitch
LenND
08-12-2007 12:35:27
The I-4 is the industrial W-4 and they were the standard version of the H.
LenND
08-12-2007 12:35:22
LenND
08-12-2007 12:35:17
dennis vanpopering
08-12-2007 12:58:46
 Re: international i-4 in reply to LenND, 08-12-2007 12:35:17
o.k. from what i hear my i-4 is the same as an h.but an h has an 152c.u.engine.mine is a 163 or 164.thats what i read on this internet somewhere.thanks
georgeky
08-12-2007 13:20:45
 Re: international i-4 in reply to dennis vanpopering, 08-12-2007 12:58:46
If your tractor is a 47 it came factory with a 152. It could have had the 164 put in it. This is a Super series engine and will fit your your tractor.
Harold H
08-12-2007 13:18:25
If you don't have the 152.1 your engine has been upgraded.
Harold H
dennis vanpopering
08-12-2007 13:23:20
 Re: international i-4 in reply to Harold H, 08-12-2007 13:18:25
o.k. on my i-4 how do i tell what engine it has?is there a number on the engine somewhere?because the.super w-4s have a 164cu engine and i read the i-4s and w-4s are the same.it just dont look like a h engine.thanks
CNKS
08-12-2007 17:45:25
 Re: international i-4 in reply to dennis vanpopering, 08-12-2007 13:23:20
There is little difference in appearance of the the H and Super H--up engines. Main outward sign is that it has a bigger carb. The 152 does not have a size designation on it, later models do, Super H C164; 300 C169; 350 C175, the numbers should be cast in the right rear side of the block. If not it originally was a 152, hard telling what has been done to it though.
