IH 444 disc brakes
Henning
08-13-2007 05:09:26
I have a IH 444 with brake problems. I don"t know much about working on these brakes. I took the brakes apart. I check the disc"s and they seem OK. The spline looks alright. The housing was filled with dirt. I cleaned everything, sprayed some brake cleaner on the disc"s, put anti-seeze on the balls. the springs seem fine. I put the brake back on and nothing. I adjusted the tension, still doesn"t seem to activate the brake. Is there a lining for the brake disc"s? There was no lining when I took them off. Is that what all the dirt inside the housing could have been? Can"t figure why I don"t have any brakes. Anyone have any suggestions what I should do?
Henning
08-13-2007 09:40:01
 Re: IH 444 disc brakes in reply to Henning, 08-13-2007 05:09:26
Thanks for the help, I'll get new disc's and hope that the answer.
HughB
08-13-2007 05:52:43
third party image
New Disc Brakes
Henning
08-13-2007 06:38:58
 Re: IH 444 disc brakes in reply to HughB, 08-13-2007 05:52:43
Where's a good place to get some new disc brakes?
IH2444
08-13-2007 07:42:17
 Re: IH 444 disc brakes in reply to Henning, 08-13-2007 06:38:58
does the parts place on here have them ?
if not there are several places to get them.
should be under $20 each disk for aftermarket ones.
IH2444
08-13-2007 07:45:54
 Re: IH 444 disc brakes in reply to IH2444, 08-13-2007 07:42:17
they have them on here
Link
Just a bit over $20 each disk not bad.
IH2444
08-13-2007 07:48:26
 Re: IH 444 disc brakes in reply to IH2444, 08-13-2007 07:45:54
BTW my friend and I replaced his discs on his 444 and he just about broke ribs on the steering wheel from stopping too fast :)
My 444 is next.
one tip as well when you put the housing back on run a bead of silicone around the edge to keep oil from the remotes and water out.
farmall66
08-13-2007 05:38:51
disc brakes are bad about crystalizing.
they should have wear groves in them. if there are no groves in them they are worn out.
