Farmall 100 Fast Hitch
Adam Brock
08-13-2007 17:22:20
Can anyone tell me if there is a manufacturer and which size is correct for the prong which goes into the coupler. I would like to buy one to adapt to a box blade to go behind my 100.
Super A
08-14-2007 05:44:49
 Re: Farmall 100 Fast Hitch in reply to Adam Brock, 08-13-2007 17:22:20
Check out Agri Supply:
Link
Al
Hugh MacKay
08-14-2007 02:35:58
Adam: I returned your e mail, however like Bill, I have forks I fabricated to match different implements. I have factory large forks on factory IH implements, factory large forks on fabrications, small forks with 1/2" flat bar welded on bottom and fabricated to 3 pioint implements and 3 forks I made using cold roll steel. Those cold roll steel forks cost me over $100. each 20 years ago, but are the best fast hitch forks I have.
formerly ny bill
08-13-2007 19:01:27
the 100 uses the large prong, with the "mast" or whatever its called on the top side. i used a piece of heavy channel for the mast, adjusted its shape with the torch, and welded it to a regular prong from a cultivator, when i built a 1 point carryall.
georgeky
08-13-2007 17:30:06
Try searching Roberts Farm Equipment, they sell them for 95 dollars a set. I don't know if they sell one at a time or not. I think they do use the large prongs like the bigger numbered series tractors. Hugh will be along and have better info.
