Question on S/N??? on M
IH RED
08-13-2007 21:32:03
what does XL after the serial number stand for?
georgeky
08-14-2007 07:35:10
 Re: Question on S/N??? on M in reply to IH RED, 08-13-2007 21:32:03
I was thinking and am not sure about what I posted last night. Seems like that should have a number between the X and L. Like X1L. Just not sure, but my suffix chart does show L for those things I listed.
georgeky
08-13-2007 23:24:40
XL means you have 5000 foot pistons, 7 MPH 4th gear and low low gear.If you have one you my friend have a rare bird. The gears alone are worth what some tractors bring. Hang on to it and take good care of it.
IH RED
08-14-2007 11:39:18
 Re: Question on S/N??? on M in reply to georgeky, 08-13-2007 23:24:40
Thanks for your help where can u find a chart on the serial numbers?? that would be nice to have...thanks again for the help and info...
georgeky
08-14-2007 13:15:15
 Re: Question on S/N??? on M in reply to IH RED, 08-14-2007 11:39:18
Not sure, but send me an email and I will send you what I have on mine.
Mike CA
08-13-2007 22:00:42
IH RED said: (quoted from post at 21:32:03 08/13/07) what does XL after the serial number stand for?
Look at it again. It's probably X1. Which means it's configured from the factory as a gasoline only tractor.
IH RED
08-14-2007 09:56:04
 Re: Question on S/N??? on M in reply to Mike CA, 08-13-2007 22:00:42
NO its XL i can read it plain and clear...
CNKS
08-14-2007 18:44:35
 Re: Question on S/N??? on M in reply to IH RED, 08-14-2007 09:56:04
I suppose it could be mis-stamped. But,IH did not intentionally use the X codes unless it was followed by a number, then there could be a letter. X1L is as Georgeky says.
