multispark problem
noidea
08-14-2007 18:24:03
What is wrong with my Summit Racing multispark ignition box. All of the wires are hooked up correct according to instructions. It would run on what seemed like two cylinders for about ten seconds. Now it won't start period. The light flashes when you turn the key to indicate that the unit is functioning properly. When I crank the engine the light doesn't flash as it should. This according to the instructions means that my pickup method isn't working. The white wire is connected directly to the post coming out of the distributor. What is wrong with it?
Randy S.E.-MN
08-15-2007 05:36:47
 Re: multispark problem in reply to noidea, 08-14-2007 18:24:03
I seem to remember your earlier post regarding the ignition box, and it seems to me you said you had it set on six cylinder mode. I don't know if you have changed this situation, but a four cylinder engine will not run on a six cylinder firing setup as the six cylinder fires every 120 degrees and (correct me if I'm wrong) a four cylinder fires at 90 or 180 degrees (usually). If this issue has been addressed, please disregard this post...Randy
Bob
08-14-2007 18:53:34
Are you still using the distributor's breaker points to trigger the igntion box?
noidea
08-14-2007 19:14:55
 Re: multispark problem in reply to Bob, 08-14-2007 18:53:34
I am using the points as the trigger. It is not a waste of money, this tractor is hopped up a good bit. A regular system wasn't good enough.
Bob
08-14-2007 19:38:51
 Re: multispark problem in reply to noidea, 08-14-2007 19:14:55
Ignition "ON", Points "open"... check the voltage at the distributor's primary terminal with a digital voltmeter.
Then, rotate the engine so the points are "closed", then check the voltage again.
What do you see?
noidea
08-14-2007 19:49:36
 Re: multispark problem in reply to Bob, 08-14-2007 19:38:51
0,14,0,14 etc
Bob
08-14-2007 19:53:26
 Re: multispark problem in reply to noidea, 08-14-2007 19:49:36
If that's the case, it sure sounds like the "box" should be getting a trigger signal.
Perhaps it was an "out of the box" failure, or could it have been jolted by someone having boosted the battery backwards, or connected the battery up backwards?
CNKS
08-14-2007 18:33:24
If you have that on a tractor you are wasting your money. If you have it on a car or truck you are wasting your money.
Janicholson
08-14-2007 18:31:44
Welllll. Testing is in order. A manual will tell you how to diagnose the sending unit. From here it is wrong for us to suggest methods due to the sensitive nature of some trigger assemblies. If you are no where near the dealer, Google the company for help. JimN
CityBoy-McCoy
08-14-2007 18:30:23
Noidea: Sounds like you may do better to call Summit and ask for their technical help desk.
mike
