Vertical distributor on H
r4etired
08-14-2007 18:59:52
Anyone know if the vertical distributor used by MandW that is ahead of the hydraulic pump is the same one that was used on H,s and M,s when they were converted from a mag. The one I have to repair appears to be shorter than the verticals I've seen. You know its time for fixin when the bushing is so bad the rotor catches on the cap and twists it at the rivet.
Bob M
08-14-2007 19:13:15
 Re: Vertical distributor on H in reply to r4etired, 08-14-2007 18:59:52
All the aftermarket vertical distributors I've seen on H/M tractors have been by Delco. Parts are not interchangeable with the IHC distributor as you have discovered.
The good news is the same Delco distributor is found on many Allis-Chalmers and Minneapolis-Moline tractors (and probably others...) of the same era. So parts should not be difficult to locate.
