504 hydraulic fluid
critty
08-15-2007 05:44:10
Hello, i just bought a gas 504 and was wondering how much fluid and what kind of fluid goes in the fill on the transmission. Also, is the rear end and the transmission the same fluid? I just ordered a manual for it but i was just wondering, thanks for any help.
Bill Thompson
08-16-2007 11:57:56
 Re: 504 hydraulic fluid in reply to critty, 08-15-2007 05:44:10
I have a 504 and it takes about 12 to 15 gallons. I put in trans-hydraulic fluid which is $13.00 2 gal. at the local farm & feet. It is all in one. One thing you need to know is if you can only shift into two gears you take the shifter out and line up the 3 or 4 nocthes ( it is also easy to fill trans fluid in that spot)and put shifter back. I welded the end of the shifter to make it fit tighter and have not had a problem. Bill Thompson
