tires for 300
Pat-CT
08-15-2007 10:02:05
is the tire size 11.2 x 38 or 13.6 by 38
Andy Motteberg
08-15-2007 20:21:50
 Re: tires for 300 in reply to Pat-CT, 08-15-2007 10:02:05
The old size was 12-38. Now it is 13.6.38.
CNKS
08-15-2007 17:01:57
11.2(10)-38 are a little small. 13.6(12)-38 are ok, but more suited to the M-450. 12.4(11)-38 are ideal.
old
08-15-2007 11:15:59
12,4X38s work real well on the 300 and the 13.6X38 will also but will speed it up just a bit. All depends on what you want out of it. If you don't mind a little fast ground speed the 13.6 is good but if you want a little slower the 12,4 works well. You do need to make sure your rims are wide enough for either one. I think if I remember right you need a min. of 10 inch rims for the 12.4 and 11 or 12 inch for the 13.6
georgeky
08-15-2007 10:21:13
11.2 belongs on a Super C. The 300 will look a lot better with 12.4 or 13.6's on it. You need to see how wide your rims are.
