MD PUMP, WILL A 400 PUMP FIT AN M?
PHILLIP W.
08-15-2007 10:29:16
I HAVE A 50 FARMALL MD AND WAS WONDERING IF A 400 PUMP WILL FIT? IF NOT WILL ANYTHING ELSE?
Brad in WI
08-15-2007 14:04:31
 How about a TD9 pump on an MD in reply to PHILLIP W., 08-15-2007 10:29:16
Not to hijack the thread but will a pump from a TD9 work on a MD. I can get one real cheap and I was thinking of putting it on for tractor pulling and enhanced field performance
D Slater
08-15-2007 18:51:48
 Re: How about a TD9 pump on an MD in reply to Brad in WI, 08-15-2007 14:04:31
Yes
Janicholson
08-15-2007 15:58:29
Sorry it will not. The engines in the 9 series are quite different. a 450 with some possible mods is the biggest. JimN
georgeky
08-15-2007 15:55:01
No, I don't think so.
farmhand
08-15-2007 13:03:57
 Re: MD PUMP, WILL A 400 PUMP FIT AN M? in reply to PHILLIP W., 08-15-2007 10:29:16
Phillip the pumps are the same and will interchange from the MD to the 450D.
georgeky
08-15-2007 12:47:32
Yes they will fit. MD,SMD,400D,450D. Pat, depending on how late a 50 model is, the live pump will fit some of them. 1950, serial number 228082 and up will accept the live pump from a SM, 400, 450.
phillip w.
08-15-2007 12:31:59
I am sorry, the injection pump is what I was questioning. Sorry for the confusion. Thank you
D Slater
08-15-2007 14:00:48
 Re: MD PUMP, WILL A 400 PUMP FIT AN M? in reply to phillip w., 08-15-2007 12:31:59
Unless your MD injection pump was switched sometime, it has a type A IH pump with a primary and scavenger pump on the rear with 3 lines plumbed to it. 400 may have a type A or B, If its a B type there will be 2 lines plumbed to primary pump and no scavenger side. A drip tube is used on the bottom of B type pump and none on A. If you switch from one type pump to the other some of the lines will need replumbed. Model number of pumps is on a metal tag on side of pumps. Some adjustment may be needed when switching certain pumps to a different engine and some will be okay.
Pat-CT
08-15-2007 11:14:58
i do not think so becuase the 400 had live hydros but what you could do is put a pump on the pto or you can by a hydraulic pump and run it off the belt that turns the fan
