1950 C oil pan question
Johnny D
08-15-2007 10:47:01
the bolt holes on the front corner of the block for the oil pan appear that they are partially stripped but there is thread up in the top which will a longer bolt will hold. It doesn"t appear to have been drilled since there are no visible signs of treads at the lower side of the hole. I have some longer bolts which came out of those holes so I am asuming that this is normal? Or were all the oil pan bolts supposed to be the same length and the bolt holes threaded from top to bottom?
red agony
08-15-2007 11:52:42
 Re: 1950 C oil pan question in reply to Johnny D, 08-15-2007 10:47:01
Yes there should be 4 (in the corners), what they do is pinch the felt seal around the crankshaft.As others have said be carefulnot to overtighten them.
gene bender
08-15-2007 19:39:58
 Re: 1950 C oil pan question in reply to red agony, 08-15-2007 11:52:42
Those bolts do not pinch the felt seal there are other bolts that tighten up around the crankshaft.
Pat-CT
08-15-2007 11:42:57
if you not removing the bolts again or not alot you can helicoil it
gene bender
08-15-2007 10:56:45
The longer bolts go in the front seal for the crank and they are pot metal and easy to strip if overtightened those holes are blind.
Johnny D
08-15-2007 11:05:29
 Re: 1950 C oil pan question in reply to gene bender, 08-15-2007 10:56:45
Best I can tell is that there are about 4 or so of them. In the corners so to speak.
