old farmall governor
tom wiseman
08-15-2007 14:02:14
i'm not sure if i have a carb problem or a governor problem. it won't go any faster than idle. This is an old tractor with a teardrop shaped gas tank and a spinning pulley on the side for running belt powered implements. i have done tuneups and such on these guys before, but i never understood how the governor works. It has direct contol over the carburator.
Janicholson
08-15-2007 17:33:39
 Re: old farmall governor in reply to tom wiseman, 08-15-2007 14:02:14
Tom,
I'd wager you have an H or an M Farmall. If there is a tube running from the governor to the carb, front to back, that is probable. There are three things that can affect the tractor as described. One is a disconnected throttle linkage from the hand lever to the governor lever in back of the governor. Check this first. The hand lever should pull the governor lever all the way it can travel when wide open. Adjust it to do so. (springs and nuts on a threaded rod left side of engine) If this does not fix it, the next place to look is the prongs and tabs inside the tube leading to the carb from the governor. Two prongs on the shaft, and one on the carb throttle shaft. they must be interlocked, and are tricky to get correct. If it still has no throttle response it is probably inside the governor. Book needed!!! but doable in every way. JimN
georgeky
08-15-2007 15:52:43
You need to determine the model of your tractor and get a manual for it. Look for a serial number and any prefix that may be in front of the number and someone here can tell you which model you have.
