1066 Cl Pedal
dwag
08-16-2007 14:47:56
How do you replace Clutch pedal shaft, part# 395249R1 on a 1066? Thanks
Cor Braakman
08-16-2007 22:47:50
 Re: 1066 Cl Pedal in reply to dwag, 08-16-2007 14:47:56
I've did the same job on my 856. I could reach it by removing the top link of the tractor. If you have long arms you can hold the nut on the inside and turn the shaft on the outside with a player
dwag
08-17-2007 07:59:20
 Re: 1066 Cl Pedal in reply to Cor Braakman, 08-16-2007 22:47:50
Blind Squirrel finds acorn!!! Took hyd pump off, and with stubby 15/16" wrench and pipe wrench, was able to remove stub shaft. Originally, I didn't know how shaft was held in place. Thanks to all for info.
the tractor vet
08-16-2007 16:39:54
the rockshaft housing has to come off to get to it.
K.B.-826
08-16-2007 15:57:14
We're talking about the shaft the clutch pedal rides on? If so, there's a castelated nut/cotter pin on the inside end of it. I THINK you can get the nut off after removing the range transmission left side cover, if not, the rockshaft housing will have to come off.
