Thresher Adjustments
Crazy Red Power
08-16-2007 15:08:50
I'm close to completing work on a McD 22x38 steel thresher & would like to know how to make the proper adjustments. I've misplaced my manual & I don't recall it being too descriptive when it came to operations, anyhow. I'm threshing oats that are weedy & have a week to sweat, yet. I'm using a Farmall H for power if that helps. I would like to know how to adjust the cleaning fan blinds, concave & sieves. I've heard a thresher can be a very efficient machine & I want to see if it's possible to get mine to work that well. Thanks in advance!
russ hamm
08-17-2007 08:31:13
 Re: Thresher Adjustments in reply to Crazy Red Power in SEWI, 08-16-2007 15:08:50
New post above, sorry, thought this one might be buried.
russ hamm
08-16-2007 15:44:38
Hang tight. I'll try to get the manual out. An h may be a lil underpowered unless it's healthy and you pitch spaced a lil. 900 on the cylinder speed should get it, do you have a tach? Are those oats bundles straight out of the field, or are you waiting a while? Oats should need less fan than wheat.
