Plugged Farmall C oil breather
CT8N
08-17-2007 07:09:39
I recently bought a nice looking 1950 C which supposedly has 14 hours on a complete overhaul. While checking it over, I found that the air breather is essentially plugged. Someone has wrapped electrical tape around the oil filler tube and jambed a cap over it so that it is sealed completely.
My question is "will the 14 hours running with a plugged oil breather damage the engine?" I have a new breather cap on order and will change the oil and filter.
Thanks
Charles
CityBoy-McCoy
08-17-2007 07:30:12
 Re: Plugged Farmall C oil breather in reply to CT8N, 08-17-2007 07:09:39
No, it probably would not harm the engine. The worst it would have done was blow a seal somewhere on the engine. If it is not dripping oil now, it was most likely not harmed. mike durhan
CT8N
08-17-2007 09:23:37
 Re: Plugged Farmall C oil breather in reply to CityBoy-McCoy, 08-17-2007 07:30:12
Thanks. That probably explains the small leak at the rear main.
Charles
