transmission
Tracy H
08-17-2007 16:48:28
I am changing the trans fluid in my 140. I was told that there is a bulge in the side of the trans that oil would run out when it was full. I cannot find it. The only bulge that I can find is one near the PTO. On right hand side of the pot housing under the belt drive put when I took it out there was a spring in the hole. So I but the bulge back in. How much gear oil does it take and what is the spring for.
Tracy H
08-17-2007 17:18:34
 Re: transmission in reply to Tracy H, 08-17-2007 16:48:28
I for got to ask does the transmission supply oil to the PTO or do you put oil in it separate.
MN Scott
08-17-2007 18:03:26
 Re: transmission in reply to Tracy H, 08-17-2007 17:18:34
The transmission supplies oil to the pto on that tractor.
Tracy H
08-17-2007 19:55:03
 Re: transmission in reply to MN Scott, 08-17-2007 18:03:26
Does the transmission supply oil to the belt drive.
MN Scott
08-17-2007 20:27:54
 Re: transmission in reply to Tracy H, 08-17-2007 19:55:03
Yep.
Hugh MacKay
08-17-2007 17:10:56
Tracy: If your looking for the fill to level plug, it's on the left, just below front end of left fender and almost directly behind brake activation pull rod. Roughly 4-5 quarts.
Tracy H
08-17-2007 17:35:28
 Re: transmission in reply to Hugh MacKay, 08-17-2007 17:10:56
Thanks for the info I found it.I for got to ask does the transmission supply oil to the PTO or do you put oil in it separate.I only have had this tractor for two weeks and I am read to play with my new toy. thanks again.
Hugh MacKay
08-18-2007 02:58:46
 Re: transmission in reply to Tracy H, 08-17-2007 17:35:28
Tracy: Scott is correct, both counts. The book actually calls for 4 quarts without belt pulley or pto and 5 quarts with. Unless you parked tractor with front end high, when you drained it, plus drained pto, your probably looking at slightly over 4 quarts. I had to remove the pto from my 140 this spring, found I still had oil, jacked front of tractor close to 6" and about another 1/2 quart came out.
Tracy H
08-18-2007 03:56:47
 Re: transmission in reply to Hugh MacKay, 08-18-2007 02:58:46
Thanks you gays you have been a big help.
Hugh MacKay
08-18-2007 04:35:52
 Re: transmission in reply to Tracy H, 08-18-2007 03:56:47
Tracy: Can't resist this one LOL. I, and I'm sure Scott don't mind being thanked, but there was no need to refer to us a as gays. hahaha. You have a good day and feel free to jump on my typo's.
