TD-14A Steering
Vic Bunn
08-17-2007 16:54:13
I acquired a TD-14A that had been sitting in the hills for around a dozen years. The left clutch is permanently engaged. So far, spraying WD-40 & banging on it hasn't helped. Transmission oil has an uninhibited path to the lower right inspection plate. I suspect a bad inner seal going to the clutch. It looks like I need to pull the ROPS (for convenience), fuel tank and all steering linkage to remove the plate above the clutches. Does this sound about right?
hector gemme
08-18-2007 03:39:45
 Re: TD-14A Steering in reply to Vic Bunn, 08-17-2007 16:54:13
Yes pull out the stering and check the seal and bearing it not a to bad job and am still have some use part for.
Janicholson
08-17-2007 18:51:20
Yes, changing the clutch probably requires that. And patience. and a big press if it is like a TD18A
JimN
