valve for 39 H or M main gas tank
Paul G. in Mn
08-18-2007 13:09:06
I am looking for a sorce for the fuel valve for the big gas tank on a 39 H and 39 M. It is a small valve just like a MD would have on the main fuel tank. on the 39's the sediment bowl was on the small tank and want to put mine back that way. Thanks Paul
randy hall
08-18-2007 19:28:14
 Re: valve for 39 H or M main gas tank in reply to Paul G. in Mn, 08-18-2007 13:09:06
paul a cdouple of the reproduction places have them.
Paul G. in Mn
08-18-2007 20:35:06
 Re: valve for 39 H or M main gas tank in reply to randy hall, 08-18-2007 19:28:14
Happen to know which ones do? Have yet to find a source
El Toro
08-18-2007 17:40:37
I don't think Case/IH has these valves anymore. You may find a valve from Imperial Eastman that you can use as a shutoof valve. They make good valves for fuel since we used a lot of them on fuel measuring devices. Hal
