2 Way Hyd Valve
sflem849
08-18-2007 19:29:20
I just bought a two way hydraulic valve on my honeymoon in Iowa! Thats right, we were at the state fair and I was asking where the junkyards were on the way from Des Moines to Wisconsin! And she approved!
I got a valve for $30 which seems like a deal compared to eBay. I havent had it apart yet so I dont know all the problems, but one main one is the handle is pretty sloppy. I also dont want to get it on and have it leak. Is there a rebuild kit available for these?
Also, I always thought my SMTA with live hyd was still only single acting. When I called my stealership they said why would you need that on an SMTA bc it is dual acting already. Everything is plugged on my tractor so I dont really know how many hoses were supposed to come off the tractor.
Thanks in advance,
Scott
rockerscraper1
08-18-2007 20:14:43
 Re: 2 Way Hyd Valve in reply to sflem849, 08-18-2007 19:29:20
you married the right woman
georgeky
08-18-2007 19:53:38
Your dealer is wrong unless it has a double acting valve on it. Live and double acting are two different things. It will operate double acting valves, but so will the old beely pump.
Wardner
08-18-2007 21:01:07
 Re: 2 Way Hyd Valve in reply to georgeky, 08-18-2007 19:53:38
George is right. You can lock the SMTA lever in its rear position and pipe the output into a IH Christmas Tree valve or aftermarket valve.
The OO series was the first to use double acting valves as standard in the big tractors. In the small tractors, I think the Cub was first in 1947.
