Seat saga continued...
Mike CA
08-18-2007 23:32:57
I dug into the seat problems some more. I thought it was a spring problem like I asked you guys. But playing with it at home I realized the seat falls sideways a bit.
third party image
First, I flipped over the seat pan, since the whole assembly felt a bit loose. I circled what I found alarming. The bolt has been worn more than half way through.
third party image
So I flipped the seat back over and noticed the right side hole had worn open as well.
third party image
Then shook the seat around yo see where else I had movement, and noticed the bolt in front of the spring was loose. So I looked in front and saw this.
third party image
So... What I believe is that I need to replace that tube that everything attaches to, and the bolt that the seat hinges on. Correct? Are they hard to find in good condition?
HENRY E NC
08-19-2007 10:36:19
 Re: Seat saga continued... in reply to Mike CA, 08-18-2007 23:32:57
All of that is repairable at little cost if you work at it. The enlarged holes and be bushed with a piece black iron pipe and the split tube can be fixed at any welding shop. Are there any vocational schools that teach welding around. I have used our community college welding shop for several items. They are glad to do it for the real experience. The pins can be made from hardend steel found in most tractor stores and some hardware stores. You might have to alter them a little but tey are strong and will work..Just think repair for a while. If you buy some old junk you will end up fixing it also. I have used all these methods on My M and now my A and I dare the first guy to tell me thats not OK.
Mike CA
08-19-2007 11:01:00
 Re: Seat saga continued... in reply to HENRY E NC, 08-19-2007 10:36:19
HENRY E NC said: (quoted from post at 10:36:19 08/19/07) All of that is repairable at little cost if you work at it. The enlarged holes and be bushed with a piece black iron pipe and the split tube can be fixed at any welding shop. Are there any vocational schools that teach welding around. I have used our community college welding shop for several items. They are glad to do it for the real experience. The pins can be made from hardend steel found in most tractor stores and some hardware stores. You might have to alter them a little but tey are strong and will work..Just think repair for a while. If you buy some old junk you will end up fixing it also. I have used all these methods on My M and now my A and I dare the first guy to tell me thats not OK.
I know a guy with welding equipment. How good he is at it I'll have to ask. I guess I'll take it apart and find out some estimates.
the tractor vet
08-19-2007 08:13:05
Looks like she was used tomuch when new.
Mike CA
08-19-2007 10:59:19
 Re: Seat saga continued... in reply to the tractor vet, 08-19-2007 08:13:05
the tractor vet said: (quoted from post at 08:13:05 08/19/07) Looks like she was used tomuch when new.
To be honest, and not to be mean, but the previous owner was pretty big. I'm 250 pounds, and he was more. I would say 300+. third party image I would say that would be the cause. I'll try to get it fixed.
Thanks for the ideas!
SDE
08-19-2007 07:11:25
Mike, take your pictures to a machine shop (on base?) and ask for their opinions. I would make a plug to slide into the end of the pipe, drill a cross hole the correct size for the pin, and weld it into the end of the pipe. The others might be able to be repaired the same way.
Only the "Correct Police" would know or care that it isn't 100% factory. Personal, I want all of my tractor to have it's original parts. SDE
georgeky
08-19-2007 04:30:59
Don't know how good it is, but there is one on ebay right now. I would think they are around. That bolt/pin of thing is worn out on mine two. Haven't checked, but it may be available from IH. That pipe could be fixed by cutting off the bad part and welding on a new piece and boring the hole/holes.
