350 Utilty Hydraulic screen Location
Dave2pa
08-19-2007 11:17:27
does anyone know where the hydraulic inlet screen is on a 350 Utlity Gas tractor ?
having hydraulic Problem and the book says to check the screen Dave
Fromjb2
08-19-2007 11:41:14
 Re: 350 Utilty Hydraulic screen Location in reply to Dave2pa, 08-19-2007 11:17:27
Dave in the hydraulic reservoir under the seat.
Have to take the VERY HEAVY top off the reservoir. You have to lift the top straight up or the screen will be damaged.
I am sure someone will give you their method of removal. I haven't done one since 1958.
Good luck
JimB
Janicholson
08-19-2007 11:40:05
Unfortunately it is under the seat. the top of the final drive casting is the resivoir, the screen is under the cast top. It is probably collapsed, many are. The solution may be to have a new one made from the old one with fine brass mesh. JimN
