Order Farmall Cub Parts Online
cub front pulley removal
W.G.
08-19-2007 15:51:49
Ive got a 1947 farmall cub the front seal is leaking. I cant see how to remove the crank pulley to replace the seal. i cant see the center bolt. thanks for the help
Keith-OR
08-19-2007 22:42:50
 Re: cub front pulley removal in reply to W.G., 08-19-2007 15:51:49
W.G. here is the puller I made to remove crank pulley from son's SC which is removed same as your cub engine. I used a porta power rather than a hydraulic jack. But a friend borrowed my puller and used a hydraulic jack, as he had one that would work laying on its' side.
In pictures I have put all the dimensions of the various parts. If you need any other info feel free to email me..
Keith & Shawn
third party image
third party image
third party image
billde
08-19-2007 17:44:58
The center bolt is used to reinstall the pulley then removed.
El Toro
08-19-2007 17:05:08
third party image
You need a puller like this one Bigdog made for his Cub. Hal
El Toro
08-20-2007 03:29:18
 Re: cub front pulley removal in reply to evilboweviel, 08-19-2007 17:47:38
You can't beat that hydraulic pressure. Hal
Bill Geer
08-19-2007 16:43:02
The pulley is a press fit. Do a search on this site.will be a lot of info.
