front bumper for a 140
Tracy H
08-20-2007 03:35:48
Can any boddy tell me where I might find a front bumber For an international 140.
Thanks Tracy H
Hugh MacKay
08-20-2007 09:36:04
 Re: front bumper for a 140 in reply to Tracy H, 08-20-2007 03:35:48
Tracy: Buy a bumper that bolts to chassis and not to front axle. The front axle type will break casting if you bump something solid, on the outer ends.
Daniel H.
08-20-2007 15:27:04
 Re: front bumper for a 140 in reply to Hugh MacKay, 08-20-2007 09:36:04
Do you have a picture of one that bolts to the chassis? The ones that bolt on the axle are all I have ever seen.
Hugh MacKay
08-20-2007 17:39:04
 Re: front bumper for a 140 in reply to Daniel H., 08-20-2007 15:27:04
Daniel: No I don't have a photo, nor do I have one. I do have a device on front of my 140 for mounting a dry chemical applicator, high enough so material flows just ahead of center mount planter. The base is a 3" chanel iron box frame going back under front axle to just below those tabs on back of cultivator mount. It is the same width as those tabs with vertical links going to the tabs on each side, then it has a heavy brace up to right side of clutch housing. It has a vertical frame about 8" in front of tyrods. It is mounted just enough below axle to allow it to pivot without striking frame.
I carries my applicator, I use it for mounting front end weight when needed. I have pushed out a few fence posts with it, pushed a few vehicles. It's still the same shape as when I built it, however if I were doing it again with bumper in mind as well as the uses I make, I'd build it with 4" chanel. I can leave this mounted when using cultivators.
CityBoy-McCoy
08-20-2007 04:47:33
Marshall's Tractor Parts. Cynthiana, KY.
georgeky
08-20-2007 09:57:27
 Re: front bumper for a 140 in reply to CityBoy-McCoy, 08-20-2007 04:47:33
Mike , what kind of commission are you getting?
CityBoy-McCoy
08-20-2007 04:51:02
888-824-0544
