10-20 SN
henryv1111
08-20-2007 07:30:16
Does anyone know where I could locate a list of the SN/year for the 10-20 tractor the SN list ont he web site for AT does not include the 10-20.
Thank YOu
Nick D
08-20-2007 07:49:34
 Re: 10-20 SN in reply to henryv1111, 08-20-2007 07:30:16
If you look under International and Farmall there is a 10-20 gear drive KC, which should be for your tractor. I am not sure why it is not under Mccormick Deering.
Bob Kerr
08-20-2007 07:49:27
Post the serial number here and I can tell you. I have a list.
henryv1111
08-20-2007 08:39:37
 Re: 10-20 SN in reply to Bob Kerr, 08-20-2007 07:49:27
I took this off of the tag under the gas tank. Its either KO or KC 176630
K-Mo
08-20-2007 09:28:44
 Re: 10-20 SN in reply to henryv1111, 08-20-2007 08:39:37
KC176630 is a 1930. The engine serial number should match, if orginal engine.
K-Mo
Bob Kerr
08-20-2007 16:25:20
 Re: 10-20 SN in reply to K-Mo, 08-20-2007 09:28:44
1930 is what I came up with also.
henryv1111
08-21-2007 07:18:50
 Re: 10-20 SN in reply to Bob Kerr, 08-20-2007 16:25:20
I found stamped under the tractor on the transmisson housing 2-14-30 did they ever stamp the date there?
Bob Kerr
08-21-2007 07:59:43
 Re: 10-20 SN in reply to henryv1111, 08-21-2007 07:18:50
Yes the main frame casting date is on the bottom. There is also the engine number stamped on a cast pad near the lower water outlet if I remember right. It should match the serial number.
