International 240
Farmallstroker
08-20-2007 17:45:01
My brother is looking at a IH240 gas w/loader. I had a couple of questions are these tractors reliable and are the hyd. strong enough to pick up a 1500lb round bale. Are they idot proof my brother lives almost two hours away and hes not very smart when it comes to equipment and I dont want to have too go and work on it every weekend.Thanks for any info.
Tyler Fortney
08-21-2007 17:42:32
 Re: International 240 in reply to Farmallstroker, 08-20-2007 17:45:01
Try a IH 460 or 560 I use a 1958 560 for the same thing ind it works great for moving 1500 lb round bales. Don't get me wrong a 240 is a good tractor but they aren't built for that.
Rob in Ore
08-21-2007 06:46:27
Jim and Gene are right on. I have a 240. I picked up a cheap homemade counterweight for the 3 point. It was made with a steel frame that held a full 55 gallon drum of cement (about 950-1000 pounds). It was all the 240 could do to lift it. When I had it on there, I was able to lift the front tires off the ground by myself. I only carried that implement once, down to a hole where I used a chain to pull the weight off and leave it in a hole. Now I have a bare frame to put a much smaller weight onto.
Janicholson
08-20-2007 18:02:24
I agree with Gene.
It is a bit less than half the tractor needed. A 350 farmall would be the smallest I would consider, and that is marginal. A 400, 450 is better suited. A rear bale spear is far more managable and safe. JimN
gene bender
08-20-2007 18:18:12
 Re: International 240 in reply to Janicholson, 08-20-2007 18:02:24
Thank you as we dont buy a S-10 to pull a 25ft fifth wheel trailer.
gene bender
08-20-2007 17:56:39
They were never designed to pick 1500 lbs thats why you see busted up tractors. If you need to move that kind of wt better spend a bunch of money and get something else. 5-700 l.bs would be the top limit. Now if you want busted spindles hard steering go ahead then we will read about another tractor that upset or rolled over.
