Final question on 350 U steering
Mark(PA)
08-21-2007 05:43:36
Hi all, I posted yesterday about possibly buying a 350U. I have taken time to read many of the posts on this website about the steering issues of these buggers!
Last night I went back over to the gentlemans house that was selling the tractor. I took it for a short spin in 1st gear. Here is what I found... When the tractor was sitting still I had to really work to get the wheels to turn. When I started in gear they turned with ease. I could feel the power steering helping then. My question is. Is this normally how that type of power steering operates or is this due to a pressure issue or something else. I assumed I would be able to spin the wheels while sitting still due to the power steering much more easily than I found was the case. Possibly this is just how they work! When moving and turning the wheel the steering seemed pretty good, with what seemed to be very little play in it. Basically only about 1" of turning on the wheel resulted in the wheels turning as well which I assume to be pretty good?
Am I off base here? and is the tightness in the steering in fact just the way it is when at a dead stop? Or is there a pressure adjustment or something that may need adjusted. The owner told me it has been that way for the time he has owned it (6 years or so). He said he doesn't believe it leaks or anything. it just worries me reading all these stories and this tractor does have an IH loader on it as well so I know it was used for those purposes for sure.
I'm just trying to weight my options! This little unit does have a IPTO and a TA in it (he said he has not used the TA ever) Starts right up and I looked for obvious cracks in the front axle and didn't see any although I wasn't able to get down underneath and look.
The price seems very reasonable at $1850. Paint is also pretty decent for sitting outside the last 5 years. he kept it tarped.
I will be using it for baling hay mostly.
Thanks!
Janicholson
08-21-2007 10:15:05
 Re: Final question on 350 U steering in reply to Mark(PA), 08-21-2007 05:43:36
That is about as good as it will get with a loader on it. Don't try to spin it while stopped. The steering is in great shape if it has only that play, as the power valving takes that much rotation to direct the oil. They will last just fine, they do not like to be turned without moving, and also from overloading the bucket. Ours would pull with an M any day of the week. We had fluid, and two sets of rear cast weights. JimN
Mark(PA)
08-21-2007 12:01:52
 Re: Final question on 350 U steering in reply to Janicholson, 08-21-2007 10:15:05
Thanks Jim, I appreciate the info. Sounds like a good deal to me. I will talk to the guy. might just buy it! thanks again. mark
ny bill
08-21-2007 07:51:49
i've never had a 300/350 utility with power steering, but the manual steering ones will get to where you can move the wheel 2 or 3" to get the wheels to steer. they shimmy like crazy in road gear if you're crazy enough to use 5th in the first place. i'd say your description is of a good buy. a tight 350 should be worth 1850 without the loader. one thought- the 28" tires on dad's 300u didn't give the traction that the 38" on his 300f had. whether thats an issue for you depends on how "hilly" it is in your part of pa. rear weights or loading the tires could help.
Mark(PA)
08-21-2007 08:37:13
 Re: Final question on 350 U steering in reply to ny bill, 08-21-2007 07:51:49
Hi Bill
Thanks for the tire info. I do have some hilly ground that does take care when baling hay or driving over. There is a decent amount of weight on the rear already due to the loader so that should help. Thanks again. I thought it was a good deal but the steering issues concerned me. I just didn't want to buy something I would regret quickly so to speak. Thanks mark
