coupler
deane ferrish
08-21-2007 10:08:21
what is the right way to install clutch shaft coupler mine was out .? I just put it in i did not know there was a proper way .It bolted up so i thought it was right.any info and pictures would be great thanks Deane
williamf
08-21-2007 15:49:24
 Re: coupler in reply to deane ferrish, 08-21-2007 10:08:21
third party image
This is the photo that Nebraska Cowman posted when I asked the same thing. I think it's a lot easier to see here than in the parts drawing.
I forget how I had done it, but it was wrong enough that I had buggered up the rubber in those odd little washer sort of things.
Good luck, Wm
deane ferrish
08-21-2007 16:50:31
 Re: coupler in reply to williamf, 08-21-2007 15:49:24
thanks a lot guys Deane
caterpillar guy
08-21-2007 12:34:27
I'm trying to remember is that the one with the square plate bent and 4 bolt holes in it? If it is they should be so the bolts on the front are ahead of the bolts to the rear half and the bolts are tapered so they go only one way if memory serves me right. another words if you lay it down on a flat surface the top holes should be front and bottom should be back.It doesn't matter which way it is laying. Hope this is clear for you .
