'56 350 Diesel
James Hand
08-21-2007 12:26:00
I have a 1956 350 Diesel that has a crack in the left side of the block. Water is not getting into the oil but I can't drive it. the engine is the Continental Diesel. Any idea where to get another block?
James Hand
James Hand
08-22-2007 05:57:05
 Re: '56 350 Diesel in reply to James Hand, 08-21-2007 12:26:00
I got several responses that will have me doing some calling and I really appreciate it a lot.
James Hand
rockerscraper1
08-21-2007 16:01:34
we fixed one couple years ago drill to stop crack , v it out grinder, clean with acetone , heat it up torch , mig welded it one of are friends left water in the 8n big hole and crack i am not saying it was the right way to fix but it worked great for us good luck
markloff
08-21-2007 14:07:32
Grove it out and fix it with JB weld. Drill small holes 1/8" in the ends of the crack so it doesn't continue to grow. If you put enough work into it you will never know it's there. Drain the block of course and heat it up good with a torch after spraying it with some carb cleaner to get the metal good and clean.
Mark
RustyFarmall
08-21-2007 13:21:58
There are several companies around that can repair that crack to the point that you will never know it was there. I've lost the link to the one that is just North of Des Moines, Iowa, but if you need it I might be able to find it again.
James Williams
08-21-2007 12:49:02
James,A crack in the side of a block is nothing new,It can be pined as the tractor sits if you can get to it.Most of them can be welded by a good experienced welder.I no this is right for a gas motor,Im sure a deisel wont make a difference.Its been my experence to work with what you have
jimmy
georgeky
08-21-2007 12:39:59
You will have a tough time finding one of those. Just start checking salvage yards. One from a 350 diesel utility is the only other tractor with that engine. You may be able to have that one repaired. Folks do amazing things with them now days.
caterpillar guy
08-21-2007 12:38:27
junk yard or used tractor parts house not sure where you are or could give you some people to call. mail me @ mdroszman@wmconnect.com Can give you some places in MI
