Re: Another 350 U Hydraulic Question
Janicholson
08-21-2007 19:12:29
The gasket can be replaced by a thin swipe of blue RTV silicone sealer. The pressure is probably reducing the size of an air bubble in the system so that fluid can get past it to the pump. If it were mine, I would put the front lower than the back by about 3 ft and see if I could get it to prime. It may be in the steel tubes where they bolt to the resivoir. Good luck, JimN
