Rear Main Leaking
SuperCmore
08-22-2007 06:36:05
The rear main on my Super C is leaking. Hasn"t gotten oil on clutch, but leaks quite a bit. Do I have to split the tractor to replace, or can it be done by removing the pan? thanks, Cmore
gene bender
08-23-2007 04:51:59
 Re: Rear Main Leaking in reply to SuperCmore, 08-22-2007 06:36:05
You have to split.
SDE
08-22-2007 20:06:46
When I replaced my ring gear on my C, I jacked it up, supported it with a jack, removed the front end, and then backed my truck under the motor. Did it outside of course. Worked quite well.
SDE
Red Dave
08-22-2007 06:40:24
You will have to split the tractor and remove the oil pan and the flywheel.
It's not all that hard of a job if you have the equipment to pick the engine off the front of the tractor and support it, but it is time consuming.
