120 semi-mounted sickle mower
Wayne from MN
08-22-2007 08:12:50
Anyone have one? Any comments on how they worked or weak spots?
I am looking at one to buy for my son to use on some pasture & weeds.
Thank you
Jossette
08-22-2007 18:51:49
 Re: 120 semi-mounted sickle mower in reply to Wayne from MN, 08-22-2007 08:12:50
third party image
I have a MM um#5 semi mount. bolts to my 400 real good. It is for sale if interested
Steven f/AZ
08-22-2007 11:27:22
Great mowers! Like already mentioned, mounting and removing can be a pain, but if you have the kick stand, a block of wood, and follow what the manual tells it"s not too bad.
Many parts common to all balanced head mowers and still available at local CIH or CNH dealer.
third party image
third party image
third party image
Al -VA
08-22-2007 10:58:20
What tractor are you putting it on? I had one and it was a great mower except taking it on and off. It always took about 20 minutes but maybe I just did not have the best routine.
GeneMO
08-22-2007 09:26:21
We basically wore out 2 of these. Very good mowers. Really check for play or looseness in the balanced head. Grasp the pully and work it back and forth. Look for up and down motion in the pitman. They need to be maintained, like anything. Keep good ledger plates and hold down clips and a good sharp sickle and they work real good. You can also adjuste the angle of the bar itself. I know we had to tilt the bar so the guards were tilted back more. We used to have trouble with mouse nests hanging up on the ends of the guards.
Gene
NawlensGator
08-22-2007 08:39:49
Pretty sturdy mowers. I use a IH 1300 balanced head sickle mower on a 3 point hitch and it works well. Same basic parts as the 120.
georgeky
08-22-2007 08:29:55
They are very good mowers and will work on almost any tractor. Parts are available at IH.
