M - H Compatibility
Robert Heft
08-22-2007 08:20:08
Hello All,
I have a 1944 Farmall M with a very good engine and a transmission that is stuck in 3rd gear. I am looking at an H with no engine and good transmission and drivetrain.
Will the M engine bolt up to the H frame / tranny / rearend easily?
Thanks,
s Robert
Andy Motteberg
08-22-2007 13:37:15
 Re: M - H Compatibility in reply to Robert Heft, 08-22-2007 08:20:08
It won't fit.
Janicholson
08-22-2007 10:43:43
If you access the forum archives for shifter repair, or M shifter tip or Stuck in gear, there will be photos of the reality. JimN
georgeky
08-22-2007 08:43:23
Robert, like Allan mentioned, you need to remove your shifter and see if it has just slipped out of the shifting rail. Is so just take a big screwdriver and slide all rails into the neutral position and put the shifter back in. This is a common problem with old tractors with a million hours on them. If this is all wrong with your M the shifter can be welde up on the end and ground back down to fit the rails much better and cure this problem.
Bob M
08-22-2007 08:32:37
No way Robert! The only thing shared between between the H and the M engine/drivetrain is the color of the paint. (Virtually EVERY part on the M is a good 30% bigger in size...)
It would require a major machining effort to graft your M engine onto the H rearend. Your time/$$$ will be much better spent sorting out your M's transmission problem!
Allan In NE
08-22-2007 08:25:12
Not even close, they are two entirely different sized tractors.
I'd be for popping that shifter up and see if ya can get 'er unstuck.
Allan
georgeky
08-22-2007 08:23:51
No.
