odd 300 U questions
vally farm
08-22-2007 20:07:01
My neibour just picked up a 300U for parts, but it has a fast hitch with the only lower mount attached to where the drawbar should go..no ability for depth control. The rocker shaft has the top link point for 3pt hitch, and the lift cyl goes along the top of the trans top cover, not up and down behind the tranny. Ser # 31128PT. Is this anything special or rare? Could this assy with top cover be moved over to a Super H (stage 1)? Any ideas would be great. Mike
georgeky
08-23-2007 08:59:54
 Re: odd 300 U questions in reply to vally farm, 08-22-2007 20:07:01
Mike, send me an email and I will send you a picture of the fast hitch on a stage one SH. Hugh, I will send you one as well.
Hugh MacKay
08-24-2007 02:56:22
 Re: odd 300 U questions in reply to georgeky, 08-23-2007 08:59:54
George: Cut the size of those photos, I'm on dialup, takes forever to down load, plus I couldn't see enough in any one view to figure out how to mount a fast hitch on a SH.
Hugh MacKay
08-23-2007 03:13:05
Mike: It is a direct bolt up to Utilities only. Letter series tractors rear casting is different and it would require a lot of modification. Your short answer, no it will not fit a letter series Farmall, not even a Farmall 300. Most of the hitch would bolt up to Farmall 300, however that lift cylinder is different.
