Farmall 100 steering problem
Fred In TN
08-23-2007 10:43:11
I need help please. I have taken the steering box apart and have the housing shaft out. I need to replace the seal that goes on the shaft above the steering arm. What is the best way to get the arm off so I can replace the seal and bearing? I have learned many things about my first tractor while reading your replies on the forum and want to thank all of you for your past help.
Fred In TN
08-24-2007 06:18:41
 Re: Farmall 100 steering problem in reply to Fred In TN, 08-23-2007 10:43:11
Thanks guys, I got the arm off last night and found it did not have a spring or spring retainer on the shaft. Does anyone have one to sell ? Thanks again for your help.
Patrick Martin
08-23-2007 17:07:32
I used a tie rod tool to get mine off. It has an end with a ramped fork and a long handle that you can hit with a hammer.
scotty
08-23-2007 11:33:42
Afternoon Fred, The steering arm is on a taper, so your going to need a small wheel puller or you might be able to pop it off using a steel wedge between the arm and the bottom of the steering box. There is a woodruff key on that tapered shaft, you will want to inspect when you have it apart !
scotty
