IH 504 rear weight
David in NH
08-23-2007 11:45:15
I have a IH 504 Diesel with a 2000 front loader on it. The tires are loaded and I also have 3 sets of wheel weights on each rear wheel. I still seem to loose traction going uphill even with the loader empty! How much weight should I add in the rear without doing damage?
Thanks again!
georgeky
08-23-2007 12:28:26
 Re: IH 504 rear weight in reply to David in NH, 08-23-2007 11:45:15
Check the air pressure in your tires. I run 8 pounds in mine for loader work.
scotty
08-23-2007 12:11:59
David, Get yourself a 55 gal drum, put a 1" bar through it about a third of the way down the barrel, and turn the ends down for your lower arms. Fill it with rocks and concrete, that will keep your front end down !
scotty
