Unusual Electric Start for an F20
Loren in Iowa
08-23-2007 16:36:11
At a recent show, I saw an F20, that had been converted to electric start, by adding a ring gear to the belt pulley, and mounting a starter on a plate bolted to the frame. Looked simple enough, and the owner says it works good. Has anybody else tried it?
Farmallgray
08-25-2007 13:13:11
 Re: Unusual Electric Start for an F20 in reply to Loren in Iowa, 08-23-2007 16:36:11
I saw an F-12 at RPRU last year that had a car flywheel on the pto shaft
with a starter. He had it all contained in a nice clean looking box that bolted to the rearend housing.
gene bender
08-25-2007 03:52:16
On the f-12,14,20 you can put a flywheel off a auto tranny motor on the driveshaft in front of the tranny and mount a starter there.
hicentered
08-24-2007 16:01:56
Loren,
I remember an article somewhere (Red Power?)in which a fellow did that with a 10-20 or 22-36 or W-30. It was done to perfection. The guy was skilled and had skilled friends if I remember right.
Paul G. in Mn
08-23-2007 18:40:43
I would like to do this to an 80 Oliver I have. Seen some nice pictures in Red power of a 10-20 a guy added that too
Bob Kerr
08-23-2007 22:15:12
 Re: Unusual Electric Start for an F20 in reply to Paul G. in Mn, 08-23-2007 18:40:43
I started my 10-20 off the belt pulleys once using an Olds 3hp hit and miss engine!
Haas
08-23-2007 18:28:59
I saw a magazine article a while back on electric start system using the belt pulley. Can't recall where it was however. Also it's possible to do the same thing using the PTO.
