Battery question
Mike CA
08-24-2007 08:52:14
I'm looking for a cheaper source for a new 6v battery. I found one 560 cranking amps. Is that about right? Too much, too little?
I'm not sure if it's a Group 1 or not, so I'll call and ask, but first I want to know what I should be looking for in cranking amps for a 6v battery.
Mike CA
08-24-2007 17:42:30
 Re: Battery question in reply to Mike CA, 08-24-2007 08:52:14
CNKS said: ...More important than the battery is the charger. You WILL need a charger for a little used tractor such as yours...
hmmm. I never thought of that. Thanks for the tip. I'll look into that as well.
Although I don't know how little my tractor is going to be used. My kids already want me to drive them all over the neighborhood on a daily basis. third party image
CNKS
08-24-2007 16:57:14
I have bought 3 or 4 of the ones Rusty mentioned the past few years. They last a long time in a Super A or C type tractor, less time in an H, which is harder to turn over. More important than the battery is the charger. You WILL need a charger for a little used tractor such as yours. It's not particularly safe to jump them from your 12 volt car or truck, I prefer not to. A decent charger is more important than the battery. A power pack would be a good substitute, don't know if they come in 6 volt, though.
Mike CA
08-24-2007 13:17:17
Closest TSC is hours away.
I'm just gonna have to start calling around. What other places might carry them other than auto parts stores?
RustyFarmall
08-24-2007 14:39:17
 Re: Battery question in reply to Mike CA, 08-24-2007 13:17:17
Grab the yellow pages. Start searching for any store that caters to farmers, hobby farmers, horse owners, etc. It does not have to be an Orscheln's or TSC. Depending on the area of the U.S. you or anybody else is in, there will be a very similar store. It will just have a totally different name.
teddy52food
08-24-2007 10:06:48
A battery never gets any better but slowly loses it"s power. A low amp battery may work for a short time but as it gets weaker it may not be enough to start an H. Get the highest amp group 1 and it will last longer and be cheaper in the long run.
RustyFarmall
08-24-2007 09:11:23
Mike, I just bought a new 6 volt for an H less than 2 hours ago. It is a group size 1, 770 cranking amps at 32 degrees F, 625 CCA at 0 degrees. Price was $45.
Mike CA
08-24-2007 10:04:03
 Re: Battery question in reply to RustyFarmall, 08-24-2007 09:11:23
RustyFarmall said: (quoted from post at 09:11:23 08/24/07) Mike, I just bought a new 6 volt for an H less than 2 hours ago. It is a group size 1, 770 cranking amps at 32 degrees F, 625 CCA at 0 degrees. Price was $45.
Where?
RustyFarmall
08-24-2007 12:08:39
 Re: Battery question in reply to Mike CA, 08-24-2007 10:04:03
Orscheln's Farm and Home. I doubt if you have any of those stores out where you live, but they handle pretty much the same brands of stuff as a TSC, and there are several other franchises that are also very similar.
For what it's worth, I priced the same battery at my local NAPA store. The NAPA store had it priced at $65, but theirs was a heavy duty rated battery. They no longer sell the less expensive version.
Pat-CT
08-24-2007 08:59:45
geeez i wish i payed more attention when i bought my 6v battery i bought the chepest one at the auto store for 30 bucks.. works fine for me
Mike CA
08-24-2007 09:03:25
 Re: Battery question in reply to Pat-CT, 08-24-2007 08:59:45
Pat-CT said: (quoted from post at 08:59:45 08/24/07) geeez i wish i payed more attention when i bought my 6v battery i bought the chepest one at the auto store for 30 bucks.. works fine for me
I wish I could find one for $30!!! So far it's $80 or $72! third party image
Wal Mart doesn't carry anything 6v in this area. ugh
HENRY E NC
08-24-2007 10:58:09
 Re: Battery question in reply to Mike CA, 08-24-2007 09:03:25
Did you ask them(Walmart) to get you one? Here they will order whatever you want if it is not in stock. Course we are in the end of the state and the closest big cities are Chattanooga 80 miles, Atlanta 120 miles Asheville 120 Charlotte 140 etc. so they are somewhat more amenable.
Mike CA
08-24-2007 11:07:46
 Re: Battery question in reply to HENRY E NC, 08-24-2007 10:58:09
HENRY E NC said: (quoted from post at 10:58:09 08/24/07) Did you ask them(Walmart) to get you one? Here they will order whatever you want if it is not in stock. Course we are in the end of the state and the closest big cities are Chattanooga 80 miles, Atlanta 120 miles Asheville 120 Charlotte 140 etc. so they are somewhat more amenable.
I sure did. They said they couldn't get anything 6v.
I suppose I could ask again when someone else is working.
Bob M
08-24-2007 09:14:33
Mike - I recently purchased two fresh "Energizer" brand group 1, 540 cranking amp batteries at Sam's Club for $32 each.
My son reports Tractor Supply has 'em also, though for a few bucks more.
Regarding cranking amp ratings, "more is better". Too few cranking amps will cause you problems. More than is required however is fine and in fact is desired.
Mike CA
08-24-2007 10:04:31
 Re: Battery question in reply to Bob M, 08-24-2007 09:14:33
Bob M said: (quoted from post at 09:14:33 08/24/07) Mike - I recently purchased two fresh "Energizer" brand group 1, 540 cranking amp batteries at Sam's Club for $32 each.
I'll have to check Costco. We don't have Sams in the local area.
