460 clutch help CNKS
TWL
08-24-2007 17:32:20
Having a hard time getting the clutch to disengage.After reading the archives it seems identical to what CNKS went through.New clutch,pressure plate,etc.Just finished checking to make sure the clutch was not in backwards.Everything seems ok.Looking at making a little longer clutch rod.Any suggestions would be greatly appreciated.
CNKS
08-24-2007 19:41:35
 Re: 460 clutch help CNKS in reply to TWL, 08-24-2007 17:32:20
I'm in the process of moving and have not had time to work on mine. At a minimum it has to be split. I don't have a clue as to what I did wrong. Clutch and TA are adjusted according to the manual.
El Toro
08-25-2007 08:23:37
 Re: 460 clutch help CNKS in reply to CNKS, 08-24-2007 19:41:35
I thought you would be finished moving by now. Hal
CNKS
08-25-2007 18:58:48
 Re: 460 clutch help CNKS in reply to El Toro, 08-25-2007 08:23:37
New house, new building, 7 tractors, all sorts of junk, not to mention what's in the house, also not to mention that I'm too old for this. Move is timed to completion of the house, which is next Wednesday, both the house and us are barely going to make it. Then I have to plant a yard, trees, put up a fence and several other things. All this makes a clutch seem like a party, if I ever get to it.
El Toro
08-25-2007 19:04:40
 Re: 460 clutch help CNKS in reply to CNKS, 08-25-2007 18:58:48
No wonder you are busy. Hal
