Janicholson: Question about sanding combine engine bore
chadd
08-24-2007 22:43:57
I have a few questions about sanding the bores. Do I just sand the little spots down, or move around the whole bore? Also, when I do sand, should I sand vertically in the bore, horizontally, or at a 45 degree angle? Should I sand until the surface is indestinguishable from the rest of the bore, or just enough that the little spots feel smoother, but still noticeable? Also, is 400 grit acceptable?
Thanks.
Janicholson
08-25-2007 05:35:08
 Re: Janicholson: Question about sanding combine engine bore in reply to chadd, 08-24-2007 22:43:57
Dear Chadd,
The best is to just take down the rust spots, leaving the remainder as little affected as possible. The 45degree answer is correct, but it will make little difference as long as it is that, or less from up and down. You will not be able to make them disappear because iron expands when rusted, and it expands out of a little pit it is making in the original. When you can't feel them, they are perfect. If over sanded, two things go wrong. The first is that that you spend too much time, the second is thet there is a chance of removing metal around the pit and causing poor sealing there. This is just a touchup to flat. 400 is OK, Good luck with the project. Remember this as the engine performs for you. Many engines with 1000 times the rust are started by brute force and survive. JimN
