FARMALL F-20
ryder96
08-25-2007 06:25:30
HOW DO YOU TELL THE DIFFERANCE BETWEEN A NARROW TREAD AND A REGULAR TREAD F-20. I HAVE A F-20 AND NOT SURE WHICH ONE IT IS.
Farmallgray
08-28-2007 15:01:40
 Re: FARMALL F-20 in reply to ryder96, 08-25-2007 06:25:30
IF F-20 IS A NARROW TREAD DOES THAT MAKE MORE OR LESS VALUABLE AND WHY?[/quote]
Narrow treads are usually worth more to most collectors. There were fewer made and they can be hauled on a narrower trailer.
the Unforgiven
08-25-2007 19:45:42
And the serial number ends with an N.
ryder96
08-26-2007 05:00:20
 Re: FARMALL F-20 in reply to the Unforgiven, 08-25-2007 19:45:42
Farmallgray
08-25-2007 12:32:21
On a narrow tread there will only be about 1/2" between the belt pulley and the final drive housing. On the standard tread it will be several inches.
Nebraska Cowman
08-25-2007 06:56:09
I look at the toe lip on the top of the rear axle. On the regular tread it's about a foot away from the dropbox and on a NT it's 6 inches or less.
