gear shifter super c
mike in va.
08-25-2007 12:00:18
MY super C seems to hang up in gear.By removing the gear shifter leaver I'am able to manualy alligh the gears an all is good for a while.The end of the shifer may be worn, but I don't know what it should look like.Does any one know of a place that I can buy a remanufactured one? Or what is a solution for this problem.
Janicholson
08-25-2007 14:10:26
 Re: gear shifter super c in reply to mike in va., 08-25-2007 12:00:18
Have it welded up on the corners of the losenge shaped tip. A little bit goes a long way. then grind it down to fit without binding in all gears. It is always trial and error because the rail slots are worn as well. JimN
