BELT PULLEY SPEED
Hay Sam
08-26-2007 08:03:00
DOES THE TA CHANGE THE SPEED ON THE BELT PULLEY??
Janicholson
08-26-2007 08:41:10
 Re: BELT PULLEY SPEED in reply to Hay Sam, 08-26-2007 08:03:00
The pulley is driven inside the trans from the an input shaft gear. The entire trans is "reduced" in speed when the TA is in reduction. (the exception to this is the IPTO system which is driven by a separate drive shaft. I do not think it hurts the tractor to use it in TA reduction, it just makes the speed wrong and that can wreck driven equipment and overload belts. Flat belt driven equipment was being phased out at the same time modern tractors were becoming more sophisticated in drive train and power management. JimN
the Unforgiven
08-26-2007 08:32:29
Yes it does, I don't remember why, but you are not supposed to use it in low.
