not sure where to post this question
tn terry t
08-26-2007 18:36:26
i have a round tank that is 31 inches across and is 56 inches long can some one tell me how to figure how much water it will hold ? also i have another tank that used to hold diesel is there any way i can get the fuel out enough to haul water in?
tn terry t
08-27-2007 17:19:20
 Re: not sure where to post this question in reply to tn terry t, 08-26-2007 18:36:26
thanks guys i knew someone would come through for me i wont need to use the diesel tank after all. a retired " backer "farmer gave me two 1000 gal tanks he used to haul transplant water in. im gona haul water for a few of my nieghbors cows .ponds are dry, people are selling out
gona try to help some of the ole timers im afraid if they have to sell out they wont be around thid old world long
James Williams
08-27-2007 13:29:27
182.56 gallons
jimmy
Janicholson
08-26-2007 21:13:26
The formula is area times height.
area is= to Pi times the radius squared
Then multiply that times the height.
JimN
F-Dean
08-26-2007 20:19:38
Sounds like a 55 gallon drum.
teddy52food
08-26-2007 19:00:17
Rinse the tank first with gasoline then with acetone and or lacuer thinner and let it dry. then rinse with water. It may be ok to water crops with but I wouldn't drink it yet.
teddy52food
08-26-2007 18:50:46
Pi (3.1416) R squared L gives you the volume in cubic inches. I don't know how many cubic inches in a gallon, maybe someone else will know. R == 1/2 the diameter times itself times the length times pi. Have I got you confused by now?
Heat Houser
08-26-2007 18:47:17
Area of the circle times length equals volume.
Area of a circle is pi(radius squared)
Since you have diameter, 1/2 is the radius.
31 divided by 2 equals 15.5 in
15.5 times 15.5 times 3.1416 equals 754.77 square inches.
754.77 times 56 equals 42,267.12 cubic inches.
There is 231 cubic inches per gallon.
42,267.12 divided by 231 equals 182.97 gallons.
rumplestiltskin
08-27-2007 08:57:36
 Re: not sure where to post this question in reply to Heat Houser, 08-26-2007 18:47:17
Heat Houser:
Nice going! THAT's how to answer a question!
Mark W. in MI
