IH tractor identity w/ case model 33 ck backhoe
bc
08-26-2007 23:41:39
Hi, just got a used IH tractor with a model 33 CK backhoe w/ serial # 4195858 and also has a loader. The hoe may not be original. The id plate is gone. It appears it may be a 560 or similar model. It has a gas engine. It won't stay running so I pulled the carb. It is a 1 & 3/8" throat so I believe it is a c-263 engine from this generic shop manual that came with it. It takes a wix 51158 oil filter (spin on type) It has a forward and reverse lever as well as a gear shift. The engine casting number is 379815R1 and the tranny casting number is 370472R4. It has a plate bolted over the pto shaft area.
Can anyone ID this tractor model and year built? It doesn't seem logical for a 560 to have a hoe hooked to it. Thanks.
bc
09-04-2007 01:36:38
 Re: IH tractor identity w/ case model 33 ck backhoe in reply to bc, 08-26-2007 23:41:39
I'm still tring to figure this out. The front radiator grille (with round holes) clearly says Industrial under the IH emblem between the headlights. In going through parts catalogs, the dash panel for the engine controls exactly matches the 460 international. None of the other models match the dash panel. The 606/2606 model tractor matches the power steering system. This must be some type of hybrid or discontinued model. Thanks.
